my SP120 Fan is not performing well
pedenski
13
I recently bought SP120 High Performance and replaced my stock cooling fan for the radiator.
looking below screenshot, my "CPU" RPM only plays around 1000 - 1300.
http://imgur.com/ySZWcMy
it worries me why its not performing as the specs says it should be, which should be around 2,000+ RPM.
is this a product defect, or this is just normal for the SP120 Corsair
The fan header CPU_FAN is almost certainly software controlled, by the motherboard if nothing else. Whatever software you are using to control fan speed, you need to adjust. If you didn't install anything, then look in the bios.
