My spectre hp x2 internal battery not charging battery not accessible
If it won't charge while it is turned on, it could be the battery is in need of replacing.
However, if it will charge when the laptop is turned off, just not when turned on, then it could actually be the charger that is the problem.
Now it is also possible that the charging circuit is damaged and in need of replacing, but I would look at the above first.
