my system goes restarted when its Idle..
Soumin
13
System Informationhttp://
For deatils info of my sys click in above link...http
Basic Info
MB-Asus Z87-A CPU-4770K RAM-HYPERX KINGSTONE PSU-750W Corsair
When ever system goes idle its simply restarted.I observe the timing approx after 18 min..
If I will working something means at least mouse is clicking its running like champ/
Temp:Temperatures:
Motherboard 39 °C (102 °F)
CPU 36 °C (97 °F)
CPU Package 44 °C (111 °F)
CPU IA Cores 44 °C (111 °F)
CPU GT Cores 40 °C (104 °F)
CPU #1 / Core #1 40 °C (104 °F)
CPU #1 / Core #2 41 °C (106 °F)
CPU #1 / Core #3 42 °C (108 °F)
CPU #1 / Core #4 43 °C (109 °F)
PCH Diode 45 °C (113 °F)
GPU Diode 39 °C (102 °F)
ST31000524AS 39 °C (102 °F)
ST3500418AS 38 °C (100 °F)
ST9250315AS 37 °C (99 °F)
I already updated Bios but it was worthless.I think problem is in PSU or Motherboard.
My PC Power mode is also High performance mode...
So I am using a utility MurGee Auto Mouse Click and using this software as a tool to awake my system.
when ever I forget .Really I am losing many things as download file corrupts. Applications files corrupted..
Help Me guys If any idea to run my system smoothly .I also test stress test it passed all .
Ram test passed
HDD Smart Checkup cleared..
Where the problem actually
Is the problem in PSU...??
Its happninig in all OS (Tested in Fresh install) win 8 8.1 and 7
Just checking - what now is Vcore?, CPU package temp? CPU fan rpm?
Check if your ram is compatible with the motherboard - go to motherboard website and see if ram is listed (QVL) and/or go to ram website and see if motherboard is listed.
https://onedrive.live.com/redir?resid=24B036727603345%21116
all details i provided in this text file
is cmos retested worth after bios update?
how to reset CMOS ..A buttn is in my mb .
Cooling Fans:
CPU 2307 RPM
Chassis #1 745 RPM
Chassis #2 813 RPM
GPU 1410 RPM (20%)
Voltage Values:
CPU Core 1.156 V
CPU VRM 1.776 V
+3.3 V 3.360 V
+5 V 5.240 V
+12 V 12.192 V
+3.3 V Standby 3.440 V
VBAT Battery 3.376 V
VCCSA 0.848 V
VTT 1.008 V
GPU Core 0.875 V
Power Values:
CPU Package 5.17 W
CPU IA Cores 0.88 W
CPU Uncore 3.11 W
DIMM 1.18 W
Debug Info T 00 00 00
Debug Info V 27 02 7F 19 7F 7F 00 (00)
https://onedrive.live.com/redir?resid=24B036727603345%2...
Cooling Fans:
CPU 2307 RPM
Chassis #1 745 RPM
Chassis #2 813 RPM
GPU 1410 RPM (20%)
Voltage Values:
CPU Core 1.156 V
CPU VRM 1.776 V
+3.3 V 3.360 V
+5 V 5.240 V
+12 V 12.192 V
VCCSA 0.848 V
VTT 1.008 V
GPU Core 0.875 V
Power Values:
CPU Package 5.17 W
CPU IA Cores 0.88 W
CPU Uncore 3.11 W
DIMM 1.18 W
Result of Hwf sennsor ..click in Below Http:// link and reply me if you ve any idea to overcome such restart issue
Sx0aXTbyapfpfijxTyn9JtMTjNZETYmyPJy0liipFm0
http://
Thanks for reply
Now I change my cpu voltage to .03...
I also reset my cmos and leave my system for 2 hrs..It is not restarted but When I move my mouse after 3 hrs.An error message is came.
Error message was about ""data could not written or placed in memory""
explorer was restarted again and again
than i try to log off ..it was not allowed me to do as restarted the explorer //
ctrl alt del was also not working. Than forcefully i d to restart..
Is my Kingstone Hyper is not compatable with asus z87 a board..
Now I Changed the temp hope it will solve ..Thanks again for replying ..
still now i don't thing problem is solved ..What will be my next step..@I7BABY
