my system is not detecting my SSD
Sahil1209
14
actually its my first build. i just turned up my system after installing my windows but wasnt using a UPS and due to power cut in my locality,my system went off.. and when it turned up it again, it stoped detecting my SSD.. please help me
If still in warranty check if you can replace that SSD. Before you do that though try switching the Sata port where it was connected with another sata port on your machine.. Maybe that part of the mother got screwed up.
If it doesnt work then surely replace the SSD.
Hope that helps.
