My system the network cable is connected then to it shows unplugged pls help me
tomatthe
Could be a bad cable, or the cable is connected to a bad port on whatever else you've got it plugged into, or it could be a hardware issue with the port itself.
Try different cables, try plugging the cable into a different router or modem or whatever it is you are connecting it to.
