My Toshiba laptop keeps going to sleep mode I need real expert advice to solve it
muhsifa14
Commendable
Mar 17, 2016
4
I have a satellite Toshiba C50-B-14D laptop keeps going to sleep mode and then the machine is being spun but nothing appears on the screen and it goes back to sleep mode
Hi,
Have you tried disabling Sleep Mode and will it still go to Sleep Mode? Here are some troubleshooting steps that may help.
- Open Power Options then click on Change Plan Settings then Change Advanced Power Settings.
- Expand Hard Disk then set Turn off Hard disk after to NEVER.
- Expand Sleep and set Allow hyrbid sleep to OFF.
- Set Hibernate after to NEVER.
- Do also set Sleep Mode to Never.
- Click Apply and OK then test it again and see if the same problem will persist or not.
