K _Kieraaaan Honorable Oct 26, 2013 2 0 10,510 Oct 26, 2013 #1 my tv native resolution is 1024x768 through vga, if i use a vga to hdmi converter box, will it output 1080p?
C Cons29 Splendid Feb 10, 2010 5,455 4 26,960 Oct 26, 2013 #2 it depends on the monitor max resolution (usually the native), even if you use hdmi, if max is below 1080, then it wont reach 1080 Upvote 0 Downvote
K _Kieraaaan Honorable Oct 26, 2013 2 0 10,510 Oct 26, 2013 #3 Cons29 : it depends on the monitor max resolution (usually the native), even if you use hdmi, if max is below 1080, then it wont reach 1080 My graphics card has a hdmi slot on it so when i do HDMI to HDMI the image is very blurry, would an upscaler fix this? Upvote 0 Downvote
