One of the fan's stopped working on my HD 7900 Series graphics card. I'm not entirely sure which graphics card I have within the 7900 series, but it looks like this (It's one of these three):
1. http://www.sapphiretech.com/productdetial.asp?Pid=983B35F1-0361-49C3-9298-D35CF776A7A5&lang=eng
2. http://www.sapphiretech.com/productdetial.asp?Pid=9213647F-B1DB-4945-BE33-8E1353666B91&lang=eng
3. http://www.sapphiretech.com/productdetial.asp?Pid=9E46D648-D654-48CC-BFA1-A619BF97729D&lang=eng
I'm sure you guys could help me narrow it down based on how much memory windows 7 say it has:
On the fan it says "Vapor-X" in white inside of a baby-blue circle. I can't find a replacement for it.
Sapphire just told me this:
But they won't tell me which graphics card I have, what size the fan is, which fans would fit it, etc.
[strike]The best I can figure out is that it's a 90mm fan? [/strike] Update: They just told me it's an 85mm fan.
Will you help me find a replacement? I'm also worried that I may be damaging my graphics card by using it while it's got one fan out. My computer has like 4-5 powerful fans in it blowing the air out. Should I not be using it until I replace the fan?
Please check with aftermarket brands like Zalman, Arctic cooling or thermaltake for replacement fan unit to fit your card.
