My VGA connector from my motherboard is not working?
thewhighet
41
I have the MSI Z77A-G45 motherboard and everything works accept the VGA connector. I know it's not the monitor or cable because they were tested on other computers. The HDMI cable coming from my graphics card however DOES work and displays the screen. What do I do to fix this?
1-While monitor is connected to graphic card PCI/AGP, power ON then press Del or F1 to open BIOS menu. Look for the setting on graphics priority. Make the motherboard's integrated graphics as priority or initial display. Save and exit. Move monitor connector to integrated VGA port of monitor.
2- A less BIOSy version would be to go to your desktop and right click the desktop then go to the properties and click the Color/resolution tab you should have the choice of two video outputs to adjust. Choose the one that is built in and click the box that says "Extend my desktop to this one" then choose the PCI one and unclick the "Make this the Default/primary video output" then choose the built in and Check the "Make this the Default/primary...
Im having the same issue. My second monitor is old and only supports VGA. But my Graphics card is only DVI and HDMI.
Is there a way to re-enable it?
u can get a DVI to VGA adapter
2- A less BIOSy version would be to go to your desktop and right click the desktop then go to the properties and click the Color/resolution tab you should have the choice of two video outputs to adjust. Choose the one that is built in and click the box that says "Extend my desktop to this one" then choose the PCI one and unclick the "Make this the Default/primary video output" then choose the built in and Check the "Make this the Default/primary video output".
Now, one thing to understand, when you put the PCI card in, and got it working correctly, your computer was forced to recognize that it would be the primary video output (controller). Anyways, you can use both, but the card is likely better.
You can reverse back to the card by doing the steps in the same order, just switch the card and built ins around.......Karz
i too have this same problem
cant we repair the onboard vga port instead of purchasing an expensive graphics card
i have a low end vga card and my pc is restarting automatically why.,.? is it because of the vga card.?
Please post a new thread, this one has nothing to do with your problem.
while opening a new thread, also post brand and model of:
CPU, motherboard and the low end vga
descibe your problem with more details
I have also the same problem buth my gpu does work buth cant install windows because the windows installer does not support it I try the one of my motherboard buth he does noet work
Please start a new thread, this one has nothing to do with your problem.
CPU, motherboard and the graphics card or the brand and model of your prebuilt PC
descibe your problem in detail
which error message exactly is showing?
is windows running and do you wanna install a graphics card driver or what exactly do you wann do?
