Question My Wi-Fi adaptor (USB Wireless LAN Card) is unable to regularly pick up mobile (cell phone) hotspots: Solved
Aug 20, 2020
Hello,
I am using a mini USB Wi-Fi adaptor to connect my desktop PC to the internet.
I am always able to pick up the signal from the JioFi 3 router (details below).
However, the Wi-Fi adaptor is not able to regularly pick up mobile (cell phone) hotspots; sometimes I can pick up the signal, sometimes not.
The other mobiles (cell phones) can pick up these mobile (cell phone) hotspots, but not my PC (via the USB adaptor).
I have tried both USB Wi-Fi adaptors, and I have tried Disabling/Enabling the USB Wireless LAN Card (in Network Connections).
Would it help to change the USB Wi-Fi adaptor, say for a one with external antenna?
Any suggestions would be greatly appreciated.
Best regards,
Ravi
Specifications of the PC, router, and USB Wireless LAN Cards:
1) PC: C2D
Processor Intel(R) Pentium(R) CPU G2030 @ 3.00GHz
Installed RAM 4.00 GB (3.41 GB usable)
OS: Windows 10 Home; Version: 2004
2) JioFi 3 Router: JMR540 WAN: LTE (2300/1800/850MHz); IEEE 802.11b/g/n 2.4G only
https://www.jio.com/shop/en-in/router-jmr540-black-/p/491193576
3) LB-Link BL-WN151 150Mbps Wireless USB Adapter -Wi-Fi with WPS Soft AP
802.11n USB Wireless LAN Card (802.11 n WLAN) from Ralink Technology, Corp.
Frequency range: 2.412 GHz – 2.472 GHz
4) Multibyte MMPL-WF01, 300 Mbps wireless-N, mini adaptor
Frequency range: 2.4 GHz – 2.4835 GHz
5) Cell phones: Micromax Q452 and Panasonic P101
Aug 20, 2020
I was able to solve the problem.
The hotspot I was not able to see was on channel 13.
I looked at the adapter's properties in the Device Manager under the Advanced tab.
There I found that Country Region (2.4GHz) was set at #0 (1-11).
I changed that to #5 (1-14).
Now my PC can see and connect to the Panasonic P101 on channel 13.
