[SOLVED] My wired networks as well wireless network not working/disconnecting.
Nvrmndryo
45
It's been a long time since I am facing this issue. It started with my wireless network, I have 2 wifi dongles, first one is tplink and second one is electron both are usb. If I connect wifi using any of this dongles, my Internet becomes so slow, my net connection is 20mbps but it becomes like 1mbps. I try to unplugged and plug the dongles but it keeps happening.
Second is, my wired lan disconnects again and again, sometimes it works for hours, I need to unplug the lan cable and plug again to work or it shows red x/disconnected.
You think my wifi dongles and onboard network adaptor is failed?
My pc config is - amd phenom ii x4 964, gigabyte ga ma785gm us2h ver.1,14gb ddr3 ram, kingston a400 250ssd.
D
Let’s make sure to rule out your router and your Internet service provider so test with an iPad or a phone or some other device and if the network is fast and reliable—then you know it’s the PC.
Whenever I’ve had issues like that with my PC unfortunately I’ve had to back up my data and perform a clean re-install of windows.
Please use the guide on Tom’s Guide If you need to reinstall windows 10 it will help you do it properly so you don’t have issues
