D
Deleted member 471947
Guest
Hi,
I have a Netgear WNA3100 Wireless Network Adapter, and I built a new PC last month, ever since then I've had an issue whereby my network adapter randomly disconnects itself from my computer. It seems to do this without fail when under heavy-load, i.e when I'm downloading a really large file or streaming a HD video on YouTube.
It gives me the windows notification sound that a USB device has been unplugged, and the icon in the toolbar turns into a little red cross. I have checked the driver and it is up to date with the Netgear driver version 5.100.68.57. My OS is Windows 8.1 Pro Preview build 9431. I had the same issue on standard windows 8 Pro, so the 8.1 update is not the cause.
Also, if I unplug the USB device and reconnect it, it instantly fixes the issue until the next time I try to download a large file. If i keep disconnecting and reconnecting it physically by hand, it shuts off all of my USB ports for a few seconds and reboots them all.
I have also checked to make sure that the option for windows to disable the device to save power is not checked, so it isn't that either.
I used the same adapter for over a year without any issues, until I upgraded my PC. The power supply is not the problem as I have had the issue with two separate power supplies which I know both work perfectly.
I have no idea what else it could be that is causing this, and really can't afford to throw money at it until it goes away, so I'm asking here, I hope you guys can help as I'm actually scared to watch videos, patch games or just download anything.
