Hey All,
Thanks for viewing my inquiry and thanks in advance if you have any thoughts on helping me sort out my PC problem. I'm new to the community, but I've been skimming the forums and blog for quite some time. I've built many workstations and game PCs but I am not by any means a pro at OC'ing. I use my PC for some mild gaming, but mostly photo/video editing and 3D rendering (I'm an Industrial Designer). Here's my build and below are some issues I'm experiencing.
OC'ing -
It doesn't appear like I have any stability issues that I know of. I've overclocked it to 4.2 and 4.0ghz (never tried anything higher since I don't care to go much higher...) with max temps under load hovering at 59 degrees Celsius. Graphics cards and everything else looks good with nothing going in RED. However, I cannot get my ram XMP profile to work for the life of me. Every time it is enabled, it fails to post or boot. So I leave it at 2133 with everything set to auto. Does this mean anything? I've also only been able to get my CPU to overclock with a BCLK set only at 100. At 125x33 it will fail to boot. However, at 100x42, it boots up fine. I have been running my CPU voltage at 1.25 and 1.275 max. I actually just left it auto on my last config and just changed the multiplier to 42 since it seems to work best in that config.
Anywho... What am I doing wrong? Why can I not apply my XMP Profile?
Rendering -
I've only had this issue as of yesterday. I actually built this PC not too long ago and due to travels I have only started using it for hardcore 3D rendering recently. Anywho, I ran a animation rendering recently at both all stock no OC settings and OC'd to 4.0ghz. Everything would work fine and hours later I would come back and the PC would be off. Simple turn back on and start rendering again. Then it shuts off while I'm on the computer during the render and I have to flip my PSU switch to turn it back on. Any thoughts on what the issue could be? Maybe my PSU is defective? At 700w, there should be plenty of headroom. During benchmarking, it only sucks up around 300-350 watts.
My Setup:
- - Asus X99WS-M Mobo
- Intel 5820K
- RAIJINTEK STYX Micro ATX case with stock 120mm case fan and H.E.C. Cougar 120mm fan installed at base sucking air from below and pushing upward to outside radiator. Maybe I should flip this?
- G-Skill Trident Z DDR4 3200 Ram (x99 compatible)
- Samsung 850 EVO 500GB
- EVGA 120-G1-0750-XR 80 PLUS GOLD 750w Modular PSU
- EVGA GeForce GTX 970
- Corsair H100i GTX
- Acer B276HK (4k IPS/60hz) and NEC (1080 IPS/60hz)
- Windows 7 Pro
- Adobe Suite, Solidworks, Sketchbook Pro, Keyshot
OC'ing -
Rendering -
My Setup:
