mycpu cooler is loud
Jose Galles
9
so i just completed my pc build a few days ago and it was not to loud, now ive just gotten a new gpu and theres way more noise. Everything works fine its just the noise, The temps is around 35-50f . Im using amd fx8350 with the stock cooler
I have the FX 8350. It's like an airplane tries to take off inside my bedroom. After A LOT of reviews I read from multiple websites, the LOUDDDD stock cooler is a problem everyone has. The temps are usually good it's just sooo loud. Buy an aftermarket CPU cooler. I can recommend you three.
Budget -> http://www.newegg.com/Product/Product.aspx?Item=N82E16835103099
One of the best air coolers -> http://www.newegg.com/Product/Product.aspx?Item=N82E16835608018
Its smaller brother if you don't like its size -> http://www.newegg.com/Product/Product.aspx?Item=N82E16835608041
P.S: I use its smaller brother and I highly recommend it.
Latest posts
