This issue is actually starting to drive me insane.
I have had it since November last year and nobody at all has been able to fix this. But I hoped one last time that anyone here could save me from this annoying as hell issue.
Basically...
at some point, not sure when, this issue starting happening where whenever I moved a piece of software from one monitor to another it would have fps drops and look bad.
http://a.pomf.se/hmbysz.mp4
This video shows that. Notice it looks to be 15-30fps?
Secondly, if I moved something intensive, again using Geforce Experience, the mouse de-syncs from its original location.
http://a.pomf.se/eazzqw.mp4
Shown by that video.
Both the monitors are 60hz.
Now, this leads onto the main issue that I assume is slightly related. The whole of everything on my PC randomly slows down to 30fps or less (I don't know exactly because I can't monitor it but it feels to be slightly less if not exactly 30fps). Watching a youtube video? 30fps. Moving windows around? 30fps. Playing some games? 30fps.
I have literally no idea what is causing this atm.
Perhaps the most easiest place to notice this is Dolphin. With V-Sync on it dives to 30fps and shows it on dolphin and while looking at msi afterburner the usage is practically 0 while it does this. https://i.imgur.com/O3Q98OJ.jpg
Notice the spikes on the usage? That pretty much correlates with the dips.
Without v-sync it does the same except it doesn't show 60fps on Dolphin but instead simply feels like it.
I noticed however that it doesn't do this anywhere nearly as much as it does while having a youtube video playing at the same time, and visible on my 2nd monitor.
http://i.imgur.com/NOqKd8I.png
The start is it alternating between 30 and 60fps for some reason and is followed by me turning off the youtube video.
It does it in WoW too. Locks to 30 randomly, and the gpu usage skyrockets downward for a few moments and then goes back up again.
Sometimes it doesn't do it as severely as others I have no idea what the correlation is.
Now then.. onto thing's I have actually tried.
It wasn't my CPU/Mobo as I tried new ones.
It wasn't my GPU as I have changed that from a 970 to a 290x.
It wasn't my RAM as I have changed that.
It wasn't my drivers as I have reinstalled them countless times.
I have also re installed Windows itself 3 times now.
It isn't the monitors themselves as I have tried both of them in different combinations with a 3rd one, and it also occurs on a single monitor as well.
It isn't my PSU as I have tried another one as well with my old gpu and it was STILL doing it.
I am actually running out of things to test, and I have no idea what's causing this VERY annoying issue.
Whoops! forgot to state my specs so here is a pastebin of my dxdiag:
http://pastebin.com/R3LuBstg
Basically...
