I need help getting my brother's PC up and running again.
Here are the specs:
ASUS Maximus VII Gene z97
Intel Core i7-4790K @ 4.0 GHz
Corsair H100i v2 Liquid Cooling
EVGA GeForce GTX 980 Ti SC+ 6GB GDDR5
Corsair Vengeance Pro 16GB DDR3
Thermaltake Toughpower Grand 850W 80+Gold
Mushkin 500GB SSD (x2)
Here are the symptoms:
PC randomly reboots while idle (30C).
PC randomly reboots while gaming (70C).
After each reboot, I get "Critical Error Kernel Power Event ID 41" in Event Viewer.
Here are the steps I've taken:
Installed Corsair H100i PRO Liquid Cooling to eliminate possibility of overheating.
Installed Crucial P1 M.2 NVMe 1TB to eliminate possibility of OS corruption.
Installed Corsair RMx 850W 80+Gold to eliminate possibility of unstable power.
Side Note:
Also, it's interesting to note that each new hardware installation has been done in my room. Afterwards, I typically let the PC run idle the entire night in my room to make sure the new hardware has been installed correctly. The PC will run like a dream the entire night in my room, however, as soon as I hook it back up in my brother's room it continues to randomly reboot. Could the issue be in wiring of his room? If so, how is he able to play on his PS4 and XBOX1 all night without any issues?
Here are the specs:
Side Note:
