G
Guest
Guest
Archived from groups: alt.comp.hardware.overclocking.amd (More info?)
Hi Guys,
Just got myself a A8V w/ AMD64 Winchester 3200+ (default 2000mhz)
I've read some crazy guys OCing it at 2995mhz...
I'm happy with mild stuff and the machine is rock solid stable at 2400mhz
(240x10) running with cpu voltage to its default 1.4v
If stable at 1.4v, then should I leave it there or should I increase the
voltage anyway?
Thanks for the info
Don't forget to remove the JUNK when you reply...
N'oubliez pas d'enlever le JUNK quand vous répondez...
Hi Guys,
voltage anyway?
Thanks for the info
