N00b Needs Help Picking Between These 4 MoBo's
aveatquevale
80
Hi, this is my build, CPU is non K model (not gonna overclock). I absolutely need onboard video, as i'll be getting a video card later on. I've already bought the memory and the ssd.
ASRock H170M Pro4 88$ Micro ATX
MSI Z170A PC MATE 90$ ATX
MSI H170 GAMING M3 100 $ ATX
Gigabyte GA-H170M-DS3H 90$ Micro ATX
My first choice is ASRock H170M Pro4 but there may be some problems acquiring this from newegg (it's complicated). Amazon is more convenient right now. What i would like to really know is if I'm missing something important in the other three compared to the ASRock H170M.
Thanks in advance to anyone who has a look or posts a reply.
I'd go with the ASRock. That's a high end motherboard with high quality sound. The MSI motherboard only has the advantage of having more PCIe slots allowing you to add more graphics cards.
I would not worry about any of the brands you have listed here. They are all good brands. You only have to start worrying when you buy into a value brand like Biostar.
Thank you for the reply, I really appreciate it. The bad user reviews on those 2 msi boards had me worried tbh. I'll probably go with the z170A, or the as rock if the price on amazon dips a little within the next week or so.
I build with Asus, the Rock and GB, MSI I stay away from due to their poor QC, I get more trouble calls on their mobos than any two other manufacturers put together. Also at this point in time (it's getting better though) you'll see a lot of bad reviews on many of the the new Z170, H170, etc mobos, it's a new socket, new CPUs, new(er) DRAM (DDR4) and many going with Win10, which still has a ways to go on a number of compatibility issues
There is almost always going to be bad reviews for a product. You only have to worry when there are a large amount of them. People are more willing to write a negative review than a positive and I know less people write a review when they are happy about their purchase.
