I'm finally putting together my water cooling set-up and I don't know what I should do with the stock case fans in the front of the case.
The items I'm working with are: 1x EK 140mm Rad, 1x EK 240mm Rad, 2x Noctua NF-P12 120mm fans, 1x Noctua NF-A14 140mm fan, and I also have the 3 original Nanoxia 140mm case fans.
I want to place the 140mm rad in the rear of the case with a 140mm fan pushing air through it and I want to place the 240mm rad in the front with the two 120mm fans pulling air through it.
I have two questions: Should I remove the 140mm case fans from the front (will the difference in size or speed cause problems with the 120mm's on the rad)? Assuming I use only the 1x 140mm in the rear (on rad) and the 2x 120mm (on rad) in the front, should I add more fans for better case air flow or will it be overkill?
[/URL][/img]
[/URL][/img]
[/URL][/img]
Thanks!
Thanks!
