NAS or USB 3.0 for my Wireless AC Netgear R7000?
EpicRed
I just picked up a new wireless ac router, Netgear R7000. It's equipped with gigabit Ethernet ports and a USB 3.0 port. I like having a centralized storage area to access files (HD 1080p movies, pictures, music).
Am I better off attaching a NAS one of the gigabit Ethernet ports or attaching a USB 3.0 external HD to it? Just looking for fast file transfer speeds, and whatever connection is best for streaming movie files to my smart tv.
Thanks.
Here's the NAS I was looking at.
http://www.amazon.com/Personal-Cloud-Storage-Share-Photos/dp/B00439GMJ2/ref=sr_1_2?ie=UTF8&qid=1416195678&sr=8-2&keywords=wd+2tb+NAS
And here is the external hard drive.
http://www.amazon.com/Book-USB-Hard-Drive-Backup/dp/B00E3RH5W2/ref=sr_1_4?ie=UTF8&qid=1416196011&sr=8-4&keywords=usb+3.0+wd+2tb
I agree. But for very casual use, the cost of dedicated NAS might not be justified. If you use that storage daily, then dedicated hardware is required in my opinion.
Het Epicred, I just bought a r7000 too and I'm in your same situation. Which choice have you made ? Feedback? Can you stream hd movies?
Thanks
