Nascar Disc problem?
eeduranty
Commendable
Jan 10, 2017
22
I am at 78 years old. My favorite game by far is Nascar 2003. I have the wheel and pedals. I put the disc in to download on HD but came up with error 36. I tried all advise
using Disc Utilities and dot_clean using Terminal. Still error 36. I put the disc in my mac ibook and got the same error message. Question could
it be the disc? Asking before I buy another.?? Thank you
Your correct error 36 is a windows message saying a set file on the CD, or Dvd rom disk could not be read, or copied from.
Or could not extract source file from medium.
You could try giving the disk a good clean if it`s scratched, but sometimes it is down the the read and write laser of the drive being weak or worn out if the drive has been in the system you have for a good few years.
You could try a cleaning disk to see if it is just dirt, or dust on the reading laser of the drive to cure the error problem.
Short of that see if you can buy a disc replacement.
Or a download image of the game disk in Iso format to run the setup and installation of Nascar 2003.
do a Google search for theIsozone.
That`s as much as I can help you...
That`s as much as I can help you, since you own original licences by buying the game you are allowed to make a backup copy of the disk or game title for your own personal use.
If you get the Iso image of the cd, or dvd disk. then you can burn the disk image to a blank record able CD-R or DVD-R disk by using burning software Eeduranty ok.
Just found the Iso image file ! click on the link bellow.
http://www.theisozone.com/downloads/pc/windows-games/nascar-racing-2003/
Unzip with winzip, and burn the Iso image to a blank CD-R medium.
I believe the answer to that is "NO" unless their is some new development a game for a
PC at 20 dollars will cost you 40/50 dollars for the same game for a Mac.
I have seen some games marked on the package for Windows and Mac
MERGED QUESTION
Question from eeduranty : "respond to an answer"
did you read your post before submitting it just to make sure your not typing right in the actual quote? maybe use the preview button before submitting it to test
