Well, I think it goes without saying that the monitor won't fit in that case. If you're going for a portable build, a 34" monitor is not a good idea.
The actual PC components will fit in that case. The GPU is a bit longer than I'd put in it, though. The max spec for slots other than 1 and 2 is 279mm. The GPU is 279mm. I'd personally prefer to play it safe, even though it will almost certainly work.
