Ncase M1v2 by Rampage FINISHED!
Rampageblack
Hi guys, I want to introduce my most recent build, which is in an Ncase M1v2 case.
Here is the main component list:
-Core i7 4790K
-Asus Z97i Plus
-Corsair Dominator Platinum 8GB 2133mhz
-Asus GTX 760 Mini
-Crucial M500 240GB M2 SSD
-Silverstone SX600-G
Watercooling component list:
-EK Supremacy ELITE
-Laing D5 from Alphacool
-Bitspower D5 mod top
-Bitspower D5 mod kit
-Swiftech MCR-H220 Radiator
-Masterkleer 16/10 Black Tubing
-1x Bitspower dual rotary adapter for pump
-4x 16/10 black nickel compression fittings
Other stuff list:
-MNPCTech case feet
-Acrylic sheet
-White led lightning with rigid pcb.
-White leds for d5 top
-Black Vandal switch with white led ring
-16AWG black cable
-connectors for custom cables
-MDPC-X black sleeving
-Cable combs
Now you have seen the specs, and now here are the pictures:
First the case itself:
MIoEFtANrtH8rPmT9QYFiSQfEf9TnvMC_eGfwjmghMk=w1292-h861-no
1fmKsCxOyuDhGzzz64APm_bWe-4csXFc_FjWJ4O5JTQ=w1292-h861-no
I made a custom side panel for the case from 5mm tinted plexi:
I got some magnetic strips for the side panel:
Custom case feet from MNPCTECH:
I've painted them with black Plasti-dip:
bnOA6DXRC-iKZxYV3q_Q6NMR2UBqlzn01kzsPOCKlZU=w1148-h861-no
Cable combs:
rWqdjsejUU8891q8WO1RBnDyn3vnoos0-rfV5JRYM1A=w574-h861-no
kh_xDBB-awVg8yrtpjUUOnC0Jk-OpLI9N7pxELPNqD8=w1148-h861-no
Rigid pcb led strip:
KQAZUqGfJ9Aw_TmGRy8GJKYgFG_AcGMpkuynRwOHhdo=w574-h861-no
Pump with Bitspower mod kit:
9ahp_3dnoYrya9kfQkmKPiBY_ExI_3XgFhIioQhV7p0=w1148-h861-no
-aipBxQGwpn3SguTZPlZ7vI4Eh8bw_2KMZHAJErQv9E=w1148-h861-no
xb0p_Vp0MssbreTAuuw9ggomLldVc8h0tXfenIaE6gM=w1148-h861-no
Swiftech rad:
Fans:
xrROyjg3DQWDYwzg1BzoW5v4irBjPPEMNHT50AsMvaE=w1292-h861-no
OlycvYPvL88u9aXV-dksz7nBuD_8P1GBpzIidcnwUXA=w1292-h861-no
I27b8FRXd4wzT6lzjbHisfcFY--BzZ_0PSJlDIq4Iyo=w1292-h861-no
EK Supremacy Elite:
EsyWg3iXcQQhVHMF2P2jXWAIUVeAphRnsb3ELUtu6dk=w1292-h861-no
zNrJvjzSao_RFakZJJzHPrmD9iVzLB3ecxXl6i0M1MQ=w574-h861-no
TpdQwYMuKTnPaWYY5im6y562oxN8E7yKLdfKt7P6CsI=w1292-h861-no
KrYafBDKK5fyarS8kl6SlwuNBoWwGbND6BfMY8jvX-g=w1292-h861-no
pZYd_Ry19x9lid7tSupDoT070eoj_SyFJnRKgakeKDE=w1292-h861-no
s1nV5WJNIK9tY6cLkE5gB-MLGE5XPbUfjSYnQdJwx7M=w1292-h861-no
I assembled the case and did some testfit for the sidepanel and made a custom bracket for the vandal switch. Here is some pics how it looks now:
I designed a custom case from aluminium for my KBC Poker 2 keyboard, and my friend CNC milled it.
Here is the result:
I changed my mind and I switched my fans to the Noiseblocker PL-2-s. I think it fits better to the dark theme.
Got some hardware pics:
I installed the painted MNPCTECH case feet:
Thats it for now. Im currently working on the custom cables and on the watercooling. Next week the tubing will arrive, then I will be able to finish the cooling loop for the cpu. When the cooling is ready im gonna take some proper pics from the hardware.
