I've decided on some core parts for my build, and narrowed some other parts down based on my requirements. Please help me fill out the remaining parts by choosing from my shortlists (or adding your own if you think there is a better option).
PC uses are very heavy Illustrator/Photoshop, gaming (but I'm not an FPS freak), lots of apps open at once on two 1920 monitors.
I'm aiming for around £1,100, but a tiny bit over would be ok.
Decided:
CPU: Intel Core i7 4790
GPU: MSI GTX 970 GAMING Twin Frozr 5
SSD: Samsung 840 Series Pro
Which CPU cooler should I get? So far I've been looking at Hyper 212 EVO (120mm), Hyper 412s Tower Cooler or maybe a Seidon 120. I won't be overclocking here so maybe these cheaper options are justified?
Which Mobo should I get? I think the Z97 chipset is the best option, so I was looking at the msi gaming 5. My big priority here is accommodating fast RAM and as much USB 3.0 action as possible - I attach a lot of devices that require it. I'd like to save here if I can, so anything around £80/$120 would be perfect.
Which RAM should I get? I'm getting 16GB but it's between Vengeance or Ripjaws. I'm leaning toward Vengeance because the Ripjaws has a higher than recommended voltage for my CPU (1.5V max recommended). Also, I've been specifically looking at 1866mhz CAS 9-10-9-27 Vengeance. Good choice?
Which PSU should I get? I think 700-750W would be best. I want to save money here if I can, so anything under £80/$120 would be ideal. I've been tempted to go for Corsair cx750m, but this is a Tier 3 PSU so might be a false economy.
Which HDD should I get? I'll most likely go for a 1TB WD Black Caviar, but suggestions for something a bit faster would be appreciated
Thanks in advance for the help!
Decided:
I notice a difference, especially during booting up. Also when opening my browser with a lot of tabs open.
