G
Guest
Guest
I just bought a new NEC FP955 19" monitor. This is my second one, because the first one I bought had a bad pixel and some geometry problems, so I exchanged it. Anyway...I thought all was well with this monitor, but I started to notice some slight <b>ghosting</b>. On certain text, I notice a repeating pattern(ghosting) to the right of the text. It is most noticable with bold text. What's strange is that large text (20pt+), has no ghosting. Otherwise, the ghosting of smaller text will not go away unless the resolution is set to 640x480. Anything above causes slight ghosting.
The video cable NEC provides has the ferrite chokes at each end. The cable is a DVI-A to D-SUB. The monitor has a DVI-A connector, which is why they include this weird DVI-A to D-SUB cable. Why it has a DVI-A input and for what purpose is beyond me! It also has a standard D-SUB, which I haven't tried yet. I know you're going to ask what type of video card I'm using.... a Hercules TNT 16MB. (Yes, you can laugh now.) This is only temporary, as I'm going to purchase a new video card soon. I also tried an old Matrox Millinium, but still notice the ghosting. With my old Sony monitor, I never had ghosting with the TNT, so I doubt it's because of the video card. Could it be caused by the video cable?
I noticed that when I lower the refresh rate, the ghosting almost disappears completely. So would it be the cards fault? Nvidia cards are known for bad 2D, but even with the Matrox (which was a good 2D card at the time), has ghosting problems.
I also have a faint <b>vertical bar</b> that is about 2 inches from the right of the screen that runs up/down. I noticed this has something to do with the contrast adjustment. When I turn down the contrast, the bar moves to the right and vice versa. It is most visible on an all white screen. My first FP955 had this vertical bar too. (I'm not talking about the Aperture Grille lines which run horizontal.) Is this vertical bar a defect of the monitor? Surely I couldn't get two monitors that have the same defect?!?!
Someone on another forum said the vertical bar would be caused by insufficient bandwidth. Is this true? He said this monitor was 200mhz monitor and nominal viewing was at 1024x768 @60hz. Well, I tried lowering my refresh rate in steps and everytime I did, the bar moved to the right until it was off screen. It disappeared at 800x600 @60hz. Any higher resolution or refresh rate at that resolution causes it to reappear.
Is this just a poorly made monitor? Since this is my 2nd FP955 to have this vertical bar, I would think it is a design flaw. How can NEC call this a <b>"professional"</b> line monitor with this problem? I want a monitor that can at least do 1600x1200 @85hz. Does a person have to get a 21" these days, in order to guarantee a "good" monitor?
<b>UPDATE:</b> I tried an ATI Radeon and still have the problems above, so it's not the video card. Any help/suggestions on a good monitor would be appreciated.<P ID="edit"><FONT SIZE=-1><EM>Edited by Wile_E on 07/08/01 02:19 AM.</EM></FONT></P>
