[SOLVED] Ned help choose case
Elad333k
Commendable
May 15, 2019
136
Need help with choose case for mid range pc that have good airflow at affordable price i have couple cases that i want dont know which one is better
First is Antec NX310 Black ATX Case come with 2 fans any1 know whats quality of those fans? Does this case could keep cold temp inside?
Second case Antec NX300 Black ATX Case it come with 4 fans that i wanna know if those fans do the job and if this case can keep cool temp inside
Last one is Sharkoon TG5 Tempered Glass same question
My pc that i gonna bulid is rx5600xt ryzen 5 3600x
Antec NX310 Black
-ARGB is proprietary and cannot be synced with motherboards that support ARGB control.
-front ARGB fan is molex powered; can't dynamically control it.
-cable management is so-so
-allows 3x 120mm, or 2x 140mm fans in front, but the panel covers most of them
Antec NX300 Black
This only includes 1 ARGB fan. I don't know where you got 4 from...
I wouldn't be surprised if this has most of the issues as the previous case; same tooling as the NX310, but a different front panel...
Honestly, most of the NX 'Gaming' series suck on a FUNCTIONAL standpoint, save for maybe the NX800.
But if you don't care about that... then whatever, right?
Bottom line of the Kitguru review...
Antec NX310 Black
Antec NX300 Black
Bottom line of the Kitguru review:
Pros
  • Decent cable management.
  • Only costs £60.
  • Includes 4 fans.
  • Space for decent size components.
  • 2 tempered glass windows.
  • Good air flow.
Cons
  • Build quality could be better in some areas.
  • Some Motherboards might conflict with top radiator mounts.
  • Fans are not RGB.
I don't even know why something subjective like RGB is even listed as a con...
The Sharkoon looks to be the most attractive of the options you're interested in.
