[SOLVED] Need 24"or more IPS 100HZor more Monitor
somesh101
290
Hi Community,
Thanks in advance.
I am looking for a new monitor. Here are my preferences. Let me know what are my options.
price : ~20K INR and < 30K in any case
Display Type: IPS
response time: Low response time for gaming 1-5ms. Doing some casual gaming after office hours.
Display Size: size 24" or more preferably wide monitor
My Current Setup is:
AMD Ryzen 1600
gtx 1060 6gb
8gb ram
480 gb ssd
and crappy 10 year old monitor samsung 2033sw
AND may be modern looking with thin bezels.
I am curating a list but whenever i some problem against a good match i get dissapointed. That's why I need your help.
Here is the current List
Productpricerefresh rateresolutionresponse timesizebrigtnesspanel typecommentlink
Acer KG271C 27inch 144Hz 160151441920 x 10801ms27400TNhttps://www.theitdepot.com/details-...z+Gaming+Monitor+(UM.HX1SI.C01)_C9P32214.html
Acer Aopen 27HC1R 27inch 144Hz Curve 172251441920x10804ms27250VAhttps://www.theitdepot.com/details-...e+Gaming+Monitor+(UM.HW1SI.P01)_C9P32192.html
MSI Optix MAG271C230001441920 x 10801ms27300VADCI: 90%https://www.theitdepot.com/details-...Curved+144Hz+1ms+Gaming+Monitor_C9P32050.html
Samsung LC24RG50FQWXXL150002401920 x 10801ms24250VAhttps://www.amazon.in/Samsung-24-in..._rd_w=VsDxR&pd_rd_wg=LYVRo&ref_=pd_gw_cr_wsim
Acer Aopen 32HC1Q 31.5inch260001442560x14404ms32250VA99srgbhttps://www.theitdepot.com/details-...e+Gaming+Monitor+(UM.JW1SI.P01)_C9P32193.html
LG Ultragear 32GK650F-B250001442560x14401ms32350VANTSC 72%/100%srgbhttps://www.amazon.in/LG-Ultragear-...7+inch&qid=1593202461&s=computers&sr=1-6&th=1
LG and Acer 32" looks good option to me,
Any help here would be great
I have an AOC 24G2/BK. It's around 200€, according to a currency converter I used, it's within your budget.
24", 1080p, 144hz refresh rate, 1ms response time, IPS panel, 250 brightness. it has thin bezels and (in my opinion) great colors. They also have the exact same monitor but with a 27" display (27G2/BK), which is 50€ more expensive (still within your budget).
Thanks for the response,
unfortunately, this model AOC 24G2/BK is not available in India.
