X xtjaga3 Honorable Jul 14, 2012 74 0 10,630 Jul 28, 2012 #1 Any recomendations? It's for gaming, and I plan on using a $250-$300 gpu with an i5-3570. Thanks.
Solution jaguarskx Jul 29, 2012 For inexpensive monitors I generally recommend Asus like the following for $165 after rebate. http://www.newegg.com/Product/Product.aspx?Item=N82E16824236102
jaguarskx Titan Apr 19, 2006 27,976 6 84,965 Jul 29, 2012 Solution #2 For inexpensive monitors I generally recommend Asus like the following for $165 after rebate. http://www.newegg.com/Product/Product.aspx?Item=N82E16824236102 Upvote 0 Downvote Solution
X xtjaga3 Honorable Jul 14, 2012 74 0 10,630 Jul 30, 2012 #3 Best answer selected by xtjaga3. Upvote 0 Downvote
jeffredo Distinguished Nov 15, 2008 1,942 0 21,310 Jul 31, 2012 #4 This this is still open I'll give you a reply I put in another thread yesterday: Don't get a crappy TN monitor when an IPS is available for the same or lower price. http://www.frys.com/product/7215383?source=googleps http://www.newegg.com/Product/Product.aspx?Item=N82E16824236288 http://www.hardwarezone.com.sg/review-asus-vs239h-p-led-monitor-ips-goodness-you-and-me Upvote 0 Downvote
