Need a 400 dollar or under gaming pc for skyrim including monitor
JaredL
23
Ok so im building my first pc i need decent specs for 400 dollars or under including a monitor i can deal with a linux os so plz help i would like
medium-high
720p/1080p
yes but monitor alone is going to be like $100 for $300 computer will be complete garbage
Best I can do within budget:
CPU: AMD A10-7850K 3.7GHz Quad-Core Processor ($151.98 @ Newegg)
Motherboard: Asus A88X-PLUS ATX FM2+ Motherboard ($81.98 @ Newegg)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-2133 Memory ($58.99 @ Newegg)
Storage: Western Digital Caviar Blue 320GB 3.5" 7200RPM Internal Hard Drive ($27.00 @ Amazon)
Case: Thermaltake Versa H22 ATX Mid Tower Case ($33.99 @ SuperBiiz)
Power Supply: XFX 550W 80+ Bronze Certified ATX Power Supply ($58.99 @ SuperBiiz)
Total: $397.93
Generated by PCPartPicker 2015-04-12 19:47 EDT-0400
It will play games like Skyrim on mostly medium settings at 1080p, will do a little better at 720p.
For reference, I have an older generation A6 APU in my Laptop, and can nearly max out Dragon Age Origins at 720p
he wants monitor in that budget too so yeah....
Oh, you're right, I didn't notice that little detail. Well if he can find a cheap $15 monitor at Goodwill or something, he can use my build for reference, lol.
Case: http://www.newegg.com/Product/Product.aspx?Item=N82E16811146075 $40
PSU: http://www.newegg.com/Product/Product.aspx?Item=N82E16817139026&cm_re=430w-_-17-139-026-_-Product $20 after rebate
CPU & MOBO: http://www.microcenter.com/site/products/amd_bundles.aspx FX8320E and ASRock 970 $120 Hands down best value for a cpu and mobo. If you dont have a Micro center near you, a 860k or G3258 with any mobo will do the job nicely
RAM: http://www.newegg.com/Product/Product.aspx?Item=N82E16820148662 $65 Great ram for a budget build
GPU: http://www.newegg.com/Product/Product.aspx?Item=N82E16814487034 Best GPU for $100 hands down.
HD: Really a personal preference, Id rather have a small ssd over a big spinning HD but everyone is different about $60-65
About $400. If you wanted Windows you could get a Legit copy for an extra $60
again he wants monitor in that 400 budget
What about an Acer X183h or X203h same model line. I found an X183h for $5 at a yard sale a few weeks ago. Very popular and cheap, search on Craigslist for one for about $20. Only 720p but that is all that you need to get started. 16:9 is a necessity don't look at anything else
