Need a bit of help
rogerm
116
I just bought a Gigabyte GA-7N400 Pro 2 and AMD Athlon XP 2800+. I've installed it all and got it up and running. Here's my question. When it boots up it says that it is running an AMD Athlon 1250MHz. If I'm not wrong a 2800+ should be running around 2GHz. Is this just the motherboard not recognizing it as 2800+ and the CPU is running correctly or do I have a problem?
Thanks for any and all help given.
