Question Need a case that fits my build
WrongRookie
680
45
4,940
I just got my new PC build but the problem is that I don't know which case will fit my build particularly the CPU cooler.
My new PC build specs
Intel core I5 13600K 3.5GHZ fourteen core LGA 1700
MSI B660 MAG Tomahawk Wifi D4 Intel LGA 1700 ATX
MSI Gaming Geforce RTX 2060 6GB GDRR6
Deepcool AK620
G.Skill Ripjaw V Series 32GB
I was thinking about this case
Corsair Tempered Glass, Alloy Steel 4000D Airflow Tempered Glass Mid-Tower ATX Case, Black (CC-9011200-WW) https://amzn.eu/d/cJYqUjl
But I like some options. My only requirements is that the case should have USB C port in case, 140 MM fans in front support and 3-4 SSD Sata drive slots. I can get a bracket if there are only 3.5 hard drive slots.
In addition the case must fit my CPU Cooler and PSU. My new PSU is Seasonic Prime Gold.
Motherboard will fit the case. Both are industry standard.
"Better options" for the case?
What would make it better in your opinion?
Cases are mostly personal preference. I've heard decent things about that case, but if there is something you don't like about it, look for something that doesn't have that issue....whatever it might be.
That AK620 cooler is 157 mm tall. Not particularly tall for its class.
Corsair 4000 D will accept coolers up to 170 mm, That's wide enough for nearly any air cooler.
That Seasonic is 6.7 inches in its longest dimension.
The Corsair 4000 D can accept power supplies up to 220 mm in length, which is 8.6 inches.
I don't see any problems.
Reactions: WrongRookie
Very sorry to disturb but will this case also fit the CPU Cooler and PSU? It looks like it has more value.
Lian Li Lancool 216 RGB Mid-Tower Alloy Steel Computer Case/Gaming Cabinet - Black | Support E-ATX/ATX/Micro-ATX/Mini-ITX | Pre-Installed 3 Front and Rear Fans - G99.LAN216RX.in https://amzn.eu/d/ajsCYPZ
Also I would like to ask that in my current PC it has two 140MM fans in the front that are magnetic
Corsair ML140 140 mm Premium Magnetic Levitation RGB LED Fan - Black (Pack of 2) https://amzn.eu/d/5YXo2w5
For the case of Lian, is it magnetic? If not does it matter in the long run whether it's magnetic or not?
Really appreciate your support.
Lancool specs above
Lancool: PSU SUPPORT LENGTH ATX (Under 220mm)
Lancool: CPU COOLER HEIGHT CLEARANCE 180.5mm (max)
I wouldn't care in the least if my fans had anything to do with magnets or magnetism, but you may have some reason.
