Need a case that supports water cooling.
That's not a bad one either, just find the one that meets your needs and preference size/colors.
Then make sure your cooling solution will fit, some cases will accept a bigger radiator than others.
the one i linked does support radiators and fans, I have it and use a h100i with fans, it doesnt support push and pull, but if your like me, the direcitons i sent let you mod it so you can, or you can do a push or pull method with it as is, and prob be fine
I run a FX9590. I could heat a small country with that processor. my idle is normally 35C sometimes a little less or more depending on what temp my office is.
that case would be fine for you more likely than not!
