Hey guys, I'm looking for some input on my below build. I plan on using the rig for gaming and photo editing and would like to run a slight overclock; I doubt I will ever expand into dual GPU territory. Although the monitor is a touch expensive, colour accuracy is more important to me than refresh, size, and max resolution. I also would like to "future-proof" the system where it makes sense to do so cost-wise e.g. the Gen3 MB that has a PCI 3 slot for a nominal increase.
I think the general components are cookie cutter but I am unsure about the PSU sizing (physical dimensions) and if the case will fit the GPU...I included a heat sink in the below list but cannot find any concrete data on whether I need one or not with my proposed build. Any component substitutes for around the same price point would be appreciated and considered.
CPU Intel Core i5-2500K retail
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=7073161&CatId=6988
Motherboard ASRock Z68 EXTREME4 GEN3
http://www.newegg.ca/Product/Product.aspx?Item=N82E16813157264
RAM "Corsair Vengeance Desktop Memory Kit - 8GB (2x 4GB), PC3-12800, DDR3-1600MHz, 9-9-9-24
http://www.newegg.ca/Product/Product.aspx?Item=N82E16820233144
Video Card XFX HD-695X-ZNDC Radeon HD 6950 XXX Video Card - 1GB
http://www.tigerdirect.ca/applicati....asp?EdpNo=7203654&csid=_23&body=REVIEWS#tabs
Hard Drive (SSD) OCZ AGT3-25SAT3-120G Agility 3 Series Solid State Drive - 120GB
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=557372&CatId=5300
Hard Drive (HDD) Western Digital WD2002FAEX Caviar Black - 2TB
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=7288043
DVD Drive Sony Optiarc AD-7260S DVD-RW
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=6246700&CatId=4
Case Bitfenix Shinobi
http://www.canadacomputers.com/product_info.php?cPath=6_112&item_id=038696
Power Supply Coolmax 500-Watt Modular Power Supply - PCI-E, 120mm Fan
http://www.tigerdirect.ca/applications/searchtools/item-details.asp?EdpNo=4435073&csid=ITD&body=MAIN
Heatsink Cooler Master Hyper 212 Plus
http://www.newegg.ca/Product/Product.aspx?Item=N82E16835103065&Tpk=Cooler Master Hyper 212 Plus
OS Windows 7 Home Premium
Monitor Dell U2412M
http://accessories.dell.com/sna/pro...e_bnrank=0&baynote_irrank=0&~ck=baynoteSearch
Any and all help is appreciated.
Monitor Dell U2412M
