Need a compatible ram module for asus p8p67 pro.
bullooka
47
Here is the list of ram modules.
1. Corsair Vengeance 8GB DDR4 LPX 2400MHz C16 RAM Kit for X99 Chipset (CMK8GX4M1A2400C16R) https://www.amazon.in/dp/B01ARHCZYO/ref=cm_sw_r_cp_apa_i_GjhEBb6Y2YDS5
2. Corsair Vengeance LPX 8GB DDR4 3000Mhz for Intel 7th, 8th Gen & Ryzen Series Motherboard, High Speed Ram CMK8GX4M1D3000C16 https://www.amazon.in/dp/B07B4FRMGV/ref=cm_sw_r_cp_apa_i_mkhEBbTAAR10C
3. HyperX Fury Black 8 GB CL15 DIMM DDR4 2400 MT/s Internal Memory (HX424C15FB2/8) https://www.amazon.in/dp/B01D8U2BKA/ref=cm_sw_r_cp_apa_i_KkhEBbSHY7W4G
4.Gskill F4-3000C16D-16GTZR TridentZ RGB Series 16GB (2x8GB) 3000MHz DDR4 CL16 Desktop Gaming Memory https://www.amazon.in/dp/B01MY9JS71/ref=cm_sw_r_cp_apa_i_alhEBbBHT3SBF
5.G.Skill Trident Z RGB Series DDR4 Memory Module (8GB X 2pcs, 3200Mhz) https://www.amazon.in/dp/B01MTDEYHU/ref=cm_sw_r_cp_apa_i_KlhEBbHDSM1M3
My system
Processor- i7 2600k
Motherboard- Asus p8p67 pro
Gpu - Msi Gtx 1060 gaming x 6g
Psu- cooler master 550w
as you have a k series processor I would get the fastest you can afford to get. the K series is meant for overclocking and matching it to a low speed RAM is like shooting yourself in the foot. if you had a locked processor or have no plans to overclock I would suggest 1600. 2200 is an oddball speed but 2133 should be easier to find
none of those
those are all DDR4
your system REQUIRES DDR3
DDR3-1600 is the fastest supported speed before overclocking
look for a matched pair of sticks, DDR3-1600 with the lowest CAS speed you can find
https://www.asus.com/Motherboards/P8P67_PRO/specifications/
Reactions: bullooka
Hi, im bit late but can you suggest something good. in the asus compatibility page it mentioned "DDR3 2200(O.C.)" does that mean i can oc any ram to 2200 or is it the compatible speed.
it means it can support that speed RAM by overclocking the memory controller. whether the RAM can run at the faster speed is something else altogether.
if you buy DDR3 2200, the motherboard is capable of running it at its stock speed, versus the chipset suggested maximum if 1600 or whatever it actually is.
