Need a CPU Cooler for my FX 6-100 with CoolerMaster K350 Case
Barretted
26
I have asked this question previously but it didn't actually give me enough information to go ahead and purchase the CPU cooler I was going to buy. So I am back once more asking the same question but with more information to make sure I get given the best answer.
Here are my computer components that you may need to know in order to answer my question:
Case: CoolerMaster K350 Midi-Tower
CPU: AMD FX-6100 3.3Ghz Processor
Motherboard: ASUSTeK Computer INC. M5A78L-M/USB3 (AM3R2)
Graphics Card: HD Radeon 7770 Ghz Edition GDDR5
With that information, I need to find an affordable, yet decent CPU cooler which will be able to fit inside my case and is compatible with my CPU components. So far I have looked at the Arctic Freezer 13 which seems to fit all of my needs, but I'm still not sure if it will be able to fit inside my case and by the looks of it, will my motherboard be able to stand the weight of it? Other than this single CPU cooler I don't know of any others that may be better and compatible with my system.
I am also looking for 2 decent 120mm fans which will be able to fit in my case for extra airflow.
