• Now's your chance win big! Join our community and get entered to win a RTX 2060 GPU, plus more! Join here.
    Pi Cast Episode 3 streams live on Tuesday, August 4th at 2:30 pm ET (7:30 PM BST). Watch live right here!
    Catch Scharon on the Tom's Hardware Show live on Thursday, August 6th at 2:00 pm ET (7:00 PM BST). Click here!
Need A CPU Temperature Monitoring Program
curt31
60
Hello I was having an overheating problem with a new i5 laptop and the motherboard was recently replaced under warrenty. I installed Core Temp and although I think it's accurate normally I'm beginning to think that the temps that are recoded when the the computer is sleep in the power saving mode might not be accurate. For example under 0-1% load the temp is usually around 15-20c but when I wake the computer up it might list a high temperature of up to 40c that to me seems odd with less power consumption. So I was hoping someone could comment on this and also suggest another program that I can use to at least verify the reading from Core Temp. Thanks for your help and assistance.
Tom j.
Conumdrum
2,397
86
I5 should do fine with HW Monitor. Or Coretemp. Or Realtemp.
Your temps of 40C aren't unusual. Please DL Prime 95, run it default for 15 minutes. It will push the processor, your fan should go to max. If temps are in the 60C range, your fine. With my massive 120x3 rad on my i7 965 I idle at the desktop at 35. It's all abut load temps. I load at 55C. You need to see under 72C under load max.
Other who know more about laptops will add info, I'm a desktop user, but an experianced cooling guy.
BTW, 40C is still only a bit over 100F, nothing that is a worry. When you hit 70C under load, then you worry, but just a bit. You will NEVER see load like Prime in normal use.
curt31
60
Say thanks for your advise I have another program called Burnin that I'm really familiar with may not want to push it quite as hard as the program you suggested also just found a program built in from Dell, I have a Dell laptop that will stress the processor, fan heat sink ect. I would like to try another temp monitoring program just to confirm the reading from Core Temp so which one would you say is best Realtemp and HW Monitor.
Tom j.
king smp
Splendid
HWMonitor will usually show about 5C higher than Coretemp since it is using
Tcase instead of Tjunction ( I think I got that right)
All that means is it uses a different way to factor temps
Also Realtemp will also be off because of different TJMax numbers it uses
Really at idle due to the slope of signal of DTS there is a lot of error
Your idle is more of a guideline than a exact measurement
whether your at 25c or 35c if that is normal operating idle with system
running optimally then what you dont want to see
is a big variance occur at same ambient room temp
For example if your ambient is 20c(68f) at you normally run at 25c and
then it raises to 35c at same ambient for no explainable reason
then there is reason to be concerned
basically if your idle is below 40c then dont worry
It is Load that matters since that is where the real accuracy of the Digital Temperature Sensor (DTS) is.
So for testing purposes really only Load Temp matters
Intel has stated that at idle there can be a normal variance of + or - 10c
The great misconception of temperature monitoring is that idle temp
unless it is properly calculated by establishing a baseline to the correct TJ Max
(which Intel has always been pretty vague about TJMax and stated to rely on
TCase instead which there specs use as max)
To have proper measurement the correct TJMax is needed
What it all comes down to is to use all three Tmonitors (HWmonitor,Coretemp and Realtemp) and run a load test (i recommend Prime95 small FFTS)
The reason for using Prime95 is that it is the most popular loader
so there is many examples of idle and load temps for different CPUs
based on using Prime95 to use as a comparison to your own numbers
Basically research you cpu and see what others are getting as temps with systems that are properly running and then use that as a baseline parameter to compare your own readings
Whew glad I am a fast typer ;)
curt31
60
Hi well thanks so much for your time do you think that Prime 95 will possibly shut the system down my processor maxes out at 105c and if it did then what would that mean I have a problem. Just got off the phone with Dell support and I was asking about the normal operating temperature range for my processor now he said that although these programs are good they are in fact measuring the core temperature of the processor and that it really doesn't reflect the True Temperature of the processor because it doesn't factor in the actual temperature were the heat sink and fan is attached and that temp is the one you should be concerned about and it's usually considerably lower maybe 10-15c do you guys agree with this I understand what he's saying and I get his point but is this really the way you should look at the CPU temperature. Well I'm a slow typeset and boy my fingers are tired. :D
Tom j.
king smp
Splendid
basically just watch CoreTemp as you use Prime95 small FFTs
if you are between ambient 20c (68f) to 24c (75f) and go over 65c and are still heading upwards then turn off Prime95
It usually takes about 15-20mins to get up to initial load temps with Prime95
keep checking on it for about a half hour
at half hour point if you are below 60c then you are doing good
between 60-65 you need extra cooling
In all actuality a CPU can go higher with core temps
above 75c is extreme danger zone
there is the core temp (temp of cores in processor package)
there is cpu temp (temp of entire processor package) which the Dell was referring to.
but using core temps is an accepted practice for computer enthusiasts since
the temp programs usually display them
though you can just add about 5c to core temp to get cpu package temperature
Daplinksta
80
4
In my experience coretemp is the go to. Laptops always have overheating issues make sure you grab a cooling pad or at least keep a fan on it in +70 F weather. I've actually had friends who game via laptop sit outside in winter to keep from an overheating shutdown.
curt31
60
Hi I've downloaded it but haven't run it yet, could you please explain what "Load Max" is exactly. Are you saying when the processor is stressed that those are the temperatures you should worry about and can you upgrade your heat sink on a laptop. Thanks
Tom j.
king smp
Splendid
Yes temps under load are the important ones
load max is when your cpu has been pushed %100 for about an half hour or more
that is what Prime95 does
You will never hit those temps under normal usage but it is good to know how high
it will go
I dont know about upgrading heatsink on a laptop but the best
bet is a good cooler matt (a pad with fans) to place laptop on
