Need a Desktop League of Legends Max settings ?
Tbz
19
Approximate Purchase Date: e.g.: this week (the closer the better)
Budget Range: 500-600 Total Price
System Usage from Most to Least Important:Gaming and Movies
Are you buying a monitor: No - have a 24 inch Samsung LED
Do you need to buy OS: No - Have Windows 7
Parts Preferences: by brand or type AMD or Intel I do not mind - but i want this pc to run for 2-3 years with max settings on league that is it
Overclocking: Does not Matter - whatever is budget friendly
Your Monitor Resolution:1920x1200
Additional Comments: League of Legends max Settings with full fps - I live in Canada so please a build from pcpartpicker would be greatly appreciated
Since LoL is actually pretty light weight you probably want to stick with something fairly cheap with good single core performance, so that would be something like a slightly overclocked Pentium G3258, or i3. Do you need the OS and monitor/keyboard/mouse or do you just need the components of the actual PC and what kind of budget?
Also - do these pcs come with cd drive - if tehy dont i can just buy external one that isnt a problem - but would be great to know - thanks
