Question Need a gaming build PC under $ 350 include monitor and OS .
MegaBahamut
BANNED
Jun 13, 2023
8
Hello guys ,
please help with gaming build for pc with monitor and Operating system under $ 350 . thanks before .
To be fair, you could build up a used system for ~$350. You would probably be considering something like one of the Dell Optiplex to "gaming" PC conversions. A plain Jane 24" 1080/60 monitor should be doable.
Check "Toasty Bros" on YT, and I think their storefront is "PC Bros", this is their market.
Reactions: MegaBahamut
@hotaru.hino : i want to run FF VII remake with 1080p on 60 fps stable , highest quality as possible bro .
If we're doing all new parts, you're not going to get this with the budget you're proposing.
Even if you go with a used system like mentioned before, you'll still be short on the budget because those things usually never come with a decent enough GPU or power supply (which is something you'll have to replace/upgrade), a decent combo for either would easily go over $300.
EDIT: Honestly, if you're willing to cough up $500, get a PS5 instead.
How about u help me with a spec that u proposing ? i couldnt work with a PS5 😀
Why not? If you want a machine specifically for gaming, a console will get you there for the budget you're proposing.
At the minimum for a gaming PC, I would argue you need to budget at least $800 just for the computer. Otherwise, the value proposition doesn't make much sense.
This is as cheap as I could find, give or take a few items. You could go less expensive on the SSD, but would be less capacity. This is with no graphics card, and I could not include a monitor either.
All from Newegg, most selected for free shipping. A few items have promotions to save a few $
Fractal Design Core 1000 M-ATX $29.99 ($8 shipping)
Refurb MSI A520M-A Pro M-ATX $49.99 (backordered to the 16th)
Ryzen 5 5600G $134
MSI Spatium M.2 2280 NVMe 1TB $34.99
G Skill Ripjaws V 2x8GB DDR4 3200 $37.99 (not ideal speed, but decent RAM for price)
EVGA 400 N1 400W PSU $41.64 (total house fire, but decent units not in budget)
This is $336.59 minus taxes, rebates. Should be worthwhile for playing at 720 until you can save more money. You will need to hit some folks up for a spare monitor, and of course keyboard and mouse.
You budget does not allow for OS either, but you can use W10 unregistered.
