Need a Graphics card for Minecraft- Slimline pc
jeripar
Hi. My son's computer needs a new graphics card that will work well for playing Minecraft and is compatible with a Slim PC. His pc is an HP Dc Series MXL2280BKF, Intel Core I5- AC, Ram-250C. HD-2012. Also, what virus protection works best for a lot of online gaming? Thank you!
As for running minecraft the Nvidia GTX 740 would be a great choice. It is a very small graphics card and will run Minecraft with ease. Look at Newegg for one, I know there under a 100 dollars.
I don't know what HP DC is that. Is it the 7000 Series? Anyway as far as I know a GTX 750Ti would be a good choice. It is small and compact and provides very good performance for $130. It doesn't require 6 pin or 8 pin cables just plug and play but It needs a Power Supply Unit that is at least 300W, So make sure that the computer has sufficient wattage. for Virus protection, I don't really know what's good. If you mean an antivirus for your computer, Bitdefender, Kaspersky is a good one. They are not free though 😀 If you want a free antivirus, Avast or Avira is descent enough. Cheers!
Zotac GTX 750Ti: http://www.amazon.com/ZOTAC-GeForce-DisplayPort-Graphics-ZT-70605-10M/dp/B00KHUE0MC/ref=sr_1_6?s=pc&ie=UTF8&qid=1443815703&sr=1-6&keywords=GTX+750Ti
