Hello I just want to clarify if is it possible to enable AMD Crossfire on AMD A8-7600 Quad Core Kaveri FM2+ to my graphics card Powercolor HD6790 1024mb 256bit GDDR5. I want to know if it is compatible. Thank you in advance & Godbless.
Your GPU will be faster than the R7 240 paired with the A8-7600.
As for the R7 250 , it will be on par with your 6790, the HD 6790 having a slight advantage.
No ithis won't be possible. You can run in dual graphics mode only paired with a R7 240 or R7 250, on the A8-7600.
Here: http://www.cpu-world.com/info/AMD/Recommended_graphics_cards_for_AMD_dual-graphics.html
Ok thank you for the reply. But one more thing, do my Powercolor HD6790 1024mb 256bit GDDR5 is greater than the A8-7600 Crossfired with R7 240 or R7 250?.
Because if my GPU is better than the dual graphics I would rather change the processor.
