Need a last check on these parts for my Gaming Build
cu1993
25
These are the parts I have selected: Just let me know what ya think or if there needs to be improvements.
Case: Rosewill Thor V2 ATX Full Tower ~~ $129.99
CPU: Intel Core i5-3570k Ivy Bridge 3.4GHz ~~ $219.99
HD: Western Digital WD RE4 500gb 7200 RPM ~~ $99.99
~~Have found an SSD for the same price http://www.newegg.com/Product/Product.aspx?Item=N82E16820171567
GPU: ASUS GTX650TI GeForce GTX 650 Ti 1GB PCI Express 3.0 x16 ~~ $159.99
PSU: Seasonic M12II 620 Bronze 620W ATX12V V2.3 / EPS 12V V2.91 SLI Ready ~~ $89.99
RAM: GSKILL Ripjaw Series 8GB (2 x 4GB) 240 Pin ddr3 ~~ $44.99
MOBO: GIGABYTE GA-Z77X-UP4 TH LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX ~~ $184.99
CD Drive: LITE-ON Black 4X Blu-ray Reader SATA Model iHOS104-06 - OEM ~~ $24.99
Total Price: $954.92 (on a slight budget)
A little note about the case: I realize that in levels of quality, the case sort of outweighs the other components. This is simply because of future upgrades which I anticipate to be soonish. However, if the case would cause a problem please let me know. It just has features that I like/looks good to me/well equipped for my future upgrades.
-- Should I go for the SSD or HDD
Thanks a ton ahead of time!!
Here you go. Don't know if you plan to overclock the CPU. If not, you could go with the i5-3750 (no K) and a cheaper motherboard and loose the CPU cooler. This would definately get you to your budget. I left out the case. A mid tower case will serve just fine for upgrading. I have 3 GPU, 4 HDDs, water cooling, and many case fans all in a mid tower case. No problem. Temps are good. and everything fits.
CPU: Intel Core i5-3570K 3.4GHz Quad-Core Processor ($189.99 @ Microcenter)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($29.98 @ Amazon)
Motherboard: ASRock Z77 Extreme4 ATX LGA1155 Motherboard ($134.98 @ Outlet PC)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1600 Memory ($49.99 @ Newegg)
Storage: Samsung 830 Series 128GB 2.5" Solid State Disk ($109.00 @ B&H)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($69.99 @ NCIX US)
Video Card: EVGA GeForce GTX 660 Ti 2GB Video Card ($269.99 @ Newegg)
Power Supply: Antec High Current Gamer 620W 80 PLUS Bronze Certified ATX12V / EPS12V Power Supply ($83.98 @ Newegg)
Optical Drive: Lite-On iHAS124-04 DVD/CD Writer ($22.98 @ Newegg)
Total: $960.88
(Generated by PCPartPicker 2012-12-31 01:56 EST-0500)
Thanks! Since this is my first build and since I really don't have a clue as to how to overclock, I don't foresee myself overclocking my cpu anytime soon. So will getting a CPU without the "K" could I get the price down?
Sure. Here you go and case is included.
CPU: Intel Core i5-3570 3.4GHz Quad-Core Processor ($208.98 @ SuperBiiz)
Motherboard: ASRock Z77 Pro3 ATX LGA1155 Motherboard ($89.99 @ Amazon)
Case: Cooler Master Gladiator 600 ATX Mid Tower Case ($59.99 @ Amazon)
Total: $964.89
(Generated by PCPartPicker 2012-12-31 02:06 EST-0500)
So heres what I got goin
PCPartPicker part list: http://pcpartpicker.com/p/v7o3
Price breakdown by merchant: http://pcpartpicker.com/p/v7o3/by_merchant/
Benchmarks: http://pcpartpicker.com/p/v7o3/benchmarks/
CPU: Intel Core i5-2500K 3.3GHz Quad-Core Processor ($209.99 @ NCIX US)
Motherboard: Gigabyte GA-Z77X-UP4 TH ATX LGA1155 Motherboard ($174.99 @ NCIX US)
Memory: G.Skill Ripjaws Series 8GB (2 x 4GB) DDR3-1600 Memory ($44.99 @ Newegg)
Storage: Western Digital RE4 500GB 3.5" 7200RPM Internal Hard Drive ($89.99 @ Adorama)
Video Card: Asus GeForce GTX 560 1GB Video Card ($149.99 @ Newegg)
Case: Rosewill THOR V2 ATX Full Tower Case ($129.99 @ Newegg)
Power Supply: SeaSonic 620W 80 PLUS Bronze Certified ATX12V / EPS12V Power Supply ($88.53 @ Amazon)
Optical Drive: Lite-On iHOS104-06 Blu-Ray/DVD/CD Drive ($24.99 @ Newegg)
Total: $913.46
(Generated by PCPartPicker 2012-12-31 02:40 EST-0500)
