Hello tomshardware.com forums, this is kind of a big post, but shouldn't be too hard to read, here we go.
Approximate Purchase Date: About a week from now
Budget Range: 550 before rebates
System Usage from Most to Least Important: gaming and then everything else
Parts Not Required: monitor, keyboard, mouse, case, dvd drive, OS (have win 7), hard drive, power supply
Preferred Website(s) for Parts: newegg.com
Country of Origin: USA
Parts Preferences: whatev
Overclocking: maybe
SLI or Crossfire: not now
Monitor Resolution: 1680 x 1050
Here is my current PC:
CPU - Intel Core 2 Duo E6750 Conroe 2.66GHz
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115029
Motherboard - ECS G33T-M2
http://www.newegg.com/Product/Product.aspx?Item=N82E16813135050
RAM - OCZ Platinum Revision 2 2GB (2 x 1GB)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227139
Video Card - MSI NX8800GTS-T2D640E-HD OC GeForce 8800 GTS 640MB
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127280
PSU - COOLER MASTER Real Power Pro RS-650-ACAA-A1 650W ATX Form Factor 12V V2.3
http://www.newegg.com/Product/Product.aspx?Item=N82E16817171023
Hard Drive - Seagate Barracuda 7200.10 ST3250410AS 250GB 7200 RPM SATA 3.0Gb/s 3.5"
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148262
Case - COOLER MASTER Centurion 534 RC-534-KKN2-GP Black Aluminum & Mesh bezel / SECC Chassis ATX Mid Tower
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119106
DVD/CD Drive - SAMSUNG 18X DVD±R DVD Burner with LightScribe Black SATA
http://www.newegg.com/Product/Product.aspx?Item=N82E16827151141
Here is what I'm thinking about purchasing:
GPU - XFX HD-695X-ZNDC Radeon HD 6950 1GB
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150524
CPU - Intel Core i5-2400 Sandy Bridge 3.1GHz (3.4GHz Turbo Boost)
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115074
Motherboard - ASRock H61M-VS LGA 1155 Intel H61 Micro ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157241
RAM - G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231311
My Questions:
Do you think my PSU and HD will continue to perform admirably for a while longer until I can purchase new ones? I've had them both for about 4 years now and haven't had any problems.
I've been having trouble deciding between a HD 6950 1gb, and a GTX 560 ti. There seems to be a lot more factory OC'd 560 ti's than 6950's, but I think that particular 6950 looks like a pretty good deal. (not really in the form of a question)
Should I find a different motherboard that supports ddr3 1600? Does 1600 make a difference for gaming compared to 1333? Because that motherboard seems like a killer deal.
I'd like to be able to play BF3 on a mix of medium and high settings while maintaining close to 60 fps. Think this will do it?
Comments:
I don't plan on upgrading my monitor to 1920 x 1080 anytime soon, I'm happy with 1680 x 1050.
I'd like to purchase in about a week, because while I want to play BF3 (oct. 25), I also want to play Red Orchestra 2, which releases on the 13th. Also, I heard something about a BF3 beta in September. And there's some other games that have come out recently or are about to come out real soon that'd I'd like to play as well.
Looking for any last minute tips and recommendations.
Thanks in advance for the help!
Overclocking: maybe
My Questions:
Comments:
You could easily get another 2-3 years out of those components.
