Need a little help please.
ravenshair
6
Hi, I am in no way computer savvy. I know a little, but its just enough to get by. So I need a little help upgrading my graphics card.
This is the system I bought: (its what I could afford at the time)
http://www.bestbuy.com/site/olspage.jsp?skuId=9361166&type=product&id=1218091498682
If you need more info, you will have to tell me how to get it cause yeah I wouldnt have a clue.
Anywho, the question I have is, what is a good graphics card for me to buy for this computer. I need it to be able to fit and everything. The case is kinda slim...so yeah..
I am on a budget of about 100 dollars. I can go to 200 I suppose if I have to, but thats max.
I play games like Sims 2. If that gives you any idea of what i need. Thanks a lot guys. 😉
Oh, keep in mind on the 9600gt, don't know about the power requirements on the low profiles. I know the normal ones do require a power connector. So keep that in mind. If your power supply seems too weak, then definitely the 4650 as that is one it's biggest advantages.
