hello, so around 3 weeks ago i bought pc parts worth 1.2k euro (in my country) which are : hi, my full build is this :
Power supply Seasonic SS-500E, 500W, bronze
CPU Cooler Be quiet! Pure Rock Slim, 92 mm
SSD Kingston Now A400 - 480GB SA400S37/480G
Graphics card Gainward GeForce GTX 1070 Ti, 8GB GDDR5
Case Evolveo T3, Black / Blue (has 3 built in fans but the motherboard only had 3 ports including the cpu cooler, also i bought 3 coolers cuz i didnt know it had prebuilt ones in it, i built my pc really slowly and i couldnt refund the 3 coolers so i have them in a package)
RAM Memory ADATA XPG GAMMIX D10 16GB (2x8GB) DDR4 2400
Motherboard ASRock AB350M-HDV
Processor AMD Ryzen 7 1700X
my problem is that i get ingame freezings, randomly, for around 10-15 seconds, audio can be heard in a loop and then it continues after 15 seconds as if nothing happened, ive tried to monitor the temperatures, temps are not the problem, ive clean installed drivers again (i removed them with the ddu software), and ive disabled a lot of windows 10 features which have been known to cause lags/freezings ingame, now the other day when i checked my motherboards website, asrock b350m-hdv, i accidentally went on the 'cpu support list' and i saw that my 1700x isnt supported, weird i said, well amd 7 1700 is there, so it could be a programming problem that they forgot to include the 'x', i go check a better version of the motherboard, b450m-hdv, and sure enough the newer motherboard supports my current cpu, i go back to the site and it says that the cpu can be supported up to 65 watt, i go check my cpu wattage and sure enough its 90 or 90 something, anyway not trying to make this long imma make it short, could this be the freezing problem? if so, what motherboard should i choose? i live in kosovo where most of the pc parts are a little overpriced (10%-15% more than in first world countries), pcpartpicker told me that my psu doesnt have an 8 pin connector therefore its not compatible, but im pretty sure it has an 6+2 pin connector which means thats a mistake through them, but the motherboard certainly doesnt have 8 pin power connector for the cpu, meaning i need a new motherboard, thats why i created this post, to double check if i really need a new motherboard or that the problem could be elsewhere, the new motherboard i chose is GA-AX370M-DS3H, please inform me asap so i dont buy more un-needed crap, thanks a lot, also i should mention that i ran the ram module error service or what is it called which is provided from windows, it came back with no errors, meaning the ram is good, it also says that only 200mb of the ram is 'hardware reserved', meaning ram is not the problem (or so i think), im gonna buy hyperx cloud X which cost 90 euro here, also the motherboard which costs 81 euro here, and im planning on getting an 144hz monitor (250 euro)after the first two purchases, i might have to wait a little more on the last though, thanks again, appreciate any responses!
