Need a little help
dandy327
Does any one know the best Motherboard for this CPU
I need it to have a raid 0,1,5,10 south bridge and the ability to have sli hookup with on board audio also DDR2 800 Memory please if anyone knows or has anything like this setup i would be grateful for your help.
CPU Intel Core 2 Quad Q6600 G0 Stepping Kentsfield 2.40GHz 8MB L2 LGA 775 Processor Retail BX80562Q6600 SLACR
http://www.clubit.com/product_detail.cfm?itemno=CA1938452
Mobo EVGA 122-CK-NF68-A1 LGA 775 NVIDIA nForce 680i SLI ATX Intel Motherboard Retail
I was looking at will this one do what i want?
http://www.clubit.com/product_detail.cfm?itemno=CA4856006
Memory I was looking at is this sufficient?
Patriot Extreme Performance 2GB (2 x 1GB) DDR2-800 CL 4-4-4-12 EPP, SLI Ready Dual Channel Kit Retail PDC22G6400LLK
http://www.clubit.com/product_detail.cfm?itemno=CA4354017
Also would it be wise to get a better heat sink than the one that comes with the CPU?
Thanks for all replys.
If you want SLI than I'm pretty sure that you have a good selection there. Not sure why you want SLI, since it's overrated, but some applications work better w/SLI (not my area of expertise). The RAM looks good to and after MIR has a nice price. There about 4 different RAM selections at newegg that end up being about the same price after MIR. Here they are for your perusal.
Memory - $97 shipped - $40 MIR = $57 Good OC’ing RAM for good money!
OCZ Platinum Revision 2 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory – Retail
http://www.newegg.com/Product/Product.asp?item=N82E16820227139
Memory - $102 shipped - $40 MIR = $62!! Solid performing CAS 4 DDR2
CORSAIR XMS2 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory – Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145034
Memory - $110 shipped - $47 MIR = $63!! Good OC’ing RAM + CAS 4 too.
Crucial Ballistix 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory – Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16820146565
Memory - $93 shipped - $30 MIR = $63!! CAS 4 and good RAM
GeIL 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16820144062
As far as needing a aftermarket CPU HSF, you will only need one if your going for heavy or extreme OC's. The stock HSF should cover most mild OC's without any issues.
