need a little monitor help
Rj Marquez
41
i have dual screens and here is my question
is there anyway to make it so you move you mouse to the left instead of to the right to get to the second screen without changing which one the main screen is?
Yes, right click your desktop and select "Screen Resolution" then where it displays your two monitors you can click and move them according to your desired orientation. Just drag one monitor so it switches to the other side , this should do the trick.
Here's a screenshot of what you should look for:
Hi, the most simple thing is to use a program called "Swap screen" (Read about it here: http://dualmonitortool.sourceforge.net/swapscreen.html )
Here is a direct download as well(Also on their website):http://sourceforge.net/projects/dualmonitortool/files/latest/download
To use the Cursor lock function open Swap Screen and go to the Cursor tab, Locate the 3rd "Change..." button and then select your wanted key combination (I Recommend doing Ctrl + Shift + any key so that you don't accidentally activate it, but you can set whatever you want.). Now go to the "General" tab and make sure "Start with Windows" is checked so you don't have to manually open the program every time. There is a lot of outer things you can do with the program as well, see if you find something you like.
