Need a mobo to finish up my build
Shuka
43
i need your suggestions for the cheapest-yet-best mobo out there that will fit this build:
CPU:
Pentium G3258
GPU:
GTX 750 1GB SuperClocked
RAM:
2X2 or 2X4, havent decided yet.
Btw, this build will be able to run modern games in medium settings,right?
Thanks!
Why is that? im buying a new one right now...
Also, can u give me a name of one...?
no thanks, got GTX 750 1GB SuperClocked for 90$ after rebate.
better overclocking support, support for much higher-clocked memory, 4 DDR3 slots, PCI-e 3.0 (though tbh we'll pretty much never hit the max bandwidth for 2.0 in our lives lol), more SATA ports (6) and no SATA 2 ports, etc. Totally up to you though.
MSI B75MA-E33. think you dont should spend more mony than that, if you dont wanna upgrade in the near future. You dont need fetures like sli and you still got support for ddr3 1600mhz and 1 sata 6
Since you're going to overclock in future, I would suggest you this great value oriented Z97 motherboard:
Asrock Z97M Pro4 Motherboard Rs.8,491 @ Primeabgb [Great deal!, IMO]
Features:
ASRock Super Alloy
- Premium Alloy Choke (Reduces 70% core loss compared to iron powder choke)
- NexFET™ MOSFET
- Sapphire Black PCB
Supports 5th Generation Intel® Core™ i7/i5/i3/Pentium®/Celeron® Processors (Socket 1150)
Supports New 4th and 4th Generation Intel® Xeon®/Core™ i7/i5/i3/Pentium®/Celeron® Processors (Socket 1150)
Solid Capacitor design, Digi Power
Supports Dual Channel DDR3 3100+(OC)
1 PCIe 3.0 x16, 1 PCIe 2.0 x16, 2 PCI
Supports AMD Quad CrossFireX™ and CrossFireX™
Graphics Output Options: D-Sub, DVI-D, HDMI
Supports Triple Monitor
7.1 CH HD Audio with Content Protection (Realtek ALC892 Audio Codec), ELNA Audio Caps
Intel® Gigabit LAN
6 SATA3, 6 USB 3.0 (2 Front, 4 Rear), 6 USB 2.0 (4 Front, 2 Rear)
1 Printer Port Header, 1 COM Port Header, 1 Thunderbolt™ AIC Connector
Supports ASRock Full Spike Protection, ASRock Cloud, APP Shop, A-Tuning, Full HD UEFI
Note:
PrimeABGB apart from being a reputed PC Components Retailer in India with their own website, they also sell the products through Amazon India.
Prime ABGB Pvt Ltd @ Amazon INDIA with 4.7 out of 5.0 stars over the past 12 months (297 ratings)
Prime ABGB Pvt Ltd @ Flipkart with almost 80% rating out of 100% with 177 Positive / 12 Neutral / 36 Negative Reviews
Also I would recommend 2 x 4GB RAM instead of 2 x 2GB, as it will help when you play latest and upcoming games. So get this:
Corsair Vengeance DDR3 8 GB (2 x 4 GB) PC DRAM (CMZ8GX3M2A1600C9R)
Cheers!
Let me fix my intention.
Im not going to overclock much, so im not gonna buy fans and stuff....
Is there anything that lets me overclock but is not so expensive and bit simpler?
I would like to know what budget you have in your mind. Also, the cheap motherboards will recognize G3258 only after you update the BIOS to latest - Meaning, you should either have at least a cheap Haswell as backup processor or borrow it from your friend, install on the motherboard you buy and flash its BIOS to latest. Then replace that processor with Intel G3258.
