You still haven't mentioned what your main usage is.
I personally would recommend your first monitor there. It has 144Hz refresh with 1mS GtG, so it is ideal for movies and games. It is a TN panel though, so color fidelity won't be as good as an IPS display. That said, unless you are a graphics professional with an eye for that sort of thing, you'd be hard pressed to tell the difference side by side.
