Need a monitor
Dazzah
162
I am looking for a monitor which has a refresh rate of 144hz, 1080p, display port, and an ips panel...it would be very nice to have thin bezzels hence why i need ips panels.
Budget of £200 and 24" or 27"
Thanks
Phil923
669
188
I would go with a 60hz IPS panel if you are planning multi monitors over a 144hz TN panel.
I would consider AOC as a good brand for budget IPS panels, good quality for a great price.
Phil923
669
188
how so? I am failing to understand your actual question now. Your budget will not allow for multiple IPS monitors, so your best bet would be to get TN panels.
Phil923
669
188
Like I said, the 60hz will not limit your actual fps UNLESS you use the Vertical Synchronization (V-Sync) option in whatever game you may play. So if you have V-Sync off, you will get to whatever FPS your two 970s allow depending on what game you are playing.
