I have an old GPU GTX 460 1 GB, this type concretely:
http://www.gigabyte.com/fileupload/product/3/3530/3282_m.jpg
Its 5 years old card, i have a problem with one of the FAN, its making a LOUD noise last couple of days, and when it starts making those LOUD noises it also starts to spin really slow. The other fan is ok. I think the first fan is probably dying, i tried even cleaning the card from dust, didnt help, made it ever worse i think.
I was thinking about getting a new cooler (pasiv+fans), for my OLD gpu, something like this:
Arctic Cooling Accelero Twin Turbo III
But then i got tip how to fix it even cheaper, the solution is to take the one fan out and just replace it with soem general 90*90mm (or something fan), and attach is with plastic straps to the pasiv part of cooling... I dont want to invest a lot of money (i can i just dont want to 🙂 ), can you think of some other solution? What would you do?
